2007 SV-211 Chirping Noise from Tranny/V-Drive
  • Landry1
    • Jun 2009
    • 32
    • Republic of Texas
    I'm trying to figure out what might be making a chirping noise in the tranny/v-drive of our SV-211. The fluids do need to be changed but the levels are good. Noise only occurs (or at least you can only hear it) when I just have the boat in drive like in a no-wake zone. Everything else with the boat is running good but after 2 tranny issues with the wifes car and my truck I'm gun-shy.
    Any ideas?
    I'm trying to get it into the shop in the next couple of weeks for fluid changes and probably won't have it on the water until so.
  • Mark2
    • Nov 2010
    • 38
    • Toronto Canada
    • 2008 SV211 Team
    There was a recall PCM put out for the tranny around your vintage (damper plate issue). Write down the serial number for your tranny and call PCM to see if its in the range for the defective units.
