cam up grade opinions
  • verticallatitude
    • Jul 2013
    • 2
    • florida
    I have a 2003 5.7 EFI and was wondering if I could change the cam with out it runing lean or rich because I can't chance the pcm programing??
    stock cam specs
    Valve Timing:006
    Duration:249/264
    Duration @ .050" Lift:197/207
    Lobe Separation:109
    Intake Centerline:106
    Valve Lift:430/450
    Lobe Lift:
    Valve Timing @ 0.006
    proposed cam specs
    Valve Timing:006
    Duration:264 270
    Duration @ .050" Lift:212/218
    Lobe Separation:112
    Intake Centerline:110
    Valve Lift:488/499
    Lobe Lift:325/33
