03 Center Engine Hatch Gas Shock size/weight?
  • mnwakerider
    • May 2011
    • 271
    • Minneapolis, MN
    Anyone know the size and weight of the gas shocks for an 03 SAN center engine cover? At work and placing an order on NautiqueParts.com and want to quite getting hit in the head with a slight breeze...
  • s_kelley2000
    • 1579
    • Fort Meadow Recevoir
    • Mass
    I am guessing it might be 40 lb 17.2" one below. The 60 lb one seems like it might be a tad too strong for the engine cover on a 3 piece hatch and the 20 lb one is most likely too soft but I am only speculating. If you call or email them they usually get back to you quickly. Even if you place the order and put in your comments what application you want it for they will check it and swap it out before the order ships if necessary. The knowledge and customer support from White Lakes never ceases to impress me.
    http://www.nautiqueparts.com/loveobs...shock-2-1.aspx
    Shawn
    2012 Blue Metal Flake SAN 230
    • mnwakerider
      • May 2011
      • 271
      • Minneapolis, MN
      great tip. and thanks!
