My ballast pumps worked fine last weekend. Today I tried to fill belly and nothing happened. Checked breaker and they were fine. Removed pump and plugged it into starboard and nothing. Starboard pump working fine, so I decided to move it to the belly. Now the starboard pump which I moved to the belly will fill but not reverse and drain. Any ideas?
When you say you removed pump and plugged it into starboard, I assume you mean you connected the pump to the starboard electrical wires. If that is the case and you know the wires are hot, then sounds like a bad pump.
The fill but not reverse sounds like an impeller. I have replaced my belly impeller as well, about the same year.2007 sv 211TE
2007 Chaparral 210
Seattle WA
