Piston for Passenger Seat on 200V Sport
  • NautiqueOasis
    • Oct 2005
    • 142
    • Dayton, OH
    • '13 200V Sport; '05 SV211; '97, '90 , '85 & '79 Sk
    I have a new '13 200V; the piston for the passenger seat (rear facing) will not keep the seat up when trying to access that storage area. Called my dealer and he had new piston sent, but after install, it is worse than the original. Both pistons are part# ML36-60; other info on piston: 7451QG 0270N 215/12 C 27. Any other owners having this problem. Does 200 direct drive have similar piston?
    '13 200V Sport Nautique
    '05 SV211 Nautique
    '97 Ski Nautique
    '90 Ski Nautique
    '85 Ski Nautique
    '79 Ski Nautique
  • lucky7t
    • Mar 2011
    • 1306
    • Oklahoma
    • 2015 SANTE
    My old 07 I went to oriellys auto parts and found a stronger piston. Just bring the old one with you
    Current Correct Craft Boat
    Correct Craft Boats Owned
    • NautiqueOasis
      • Oct 2005
      • 142
      • Dayton, OH
      That is certainly my plan; just a shame I can't get the appropriate piston from Nautique. I was just wondering whether other owners felt the piston did not adequately hold their seat up.
      '05 SV211 Nautique
      '97 Ski Nautique
      '90 Ski Nautique
      '85 Ski Nautique
      '79 Ski Nautique
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        You're looking for a "gas spring." Amazon has them as well as other online sources. The important factors are the length and strength. Those numbers you have indicate that but I can't remember how it's noted at the moment. A google search should sort that out for you.
        -Charles
        • Surfsmith
          • Oct 2010
          • 73
          • IA
          • 11 Sport 200 03 206 LE 95 Sport Nautique
          Mine is ML36-80. Holds seat up ok.
          11 200V
          03 Nautique 206
          95 Sport Nautique
          • scottb7
            • Aug 2011
            • 2198
            • Carson City, Nevada
            They definitely are pretty bad. In my 2008 I had to replace like 6 or 7 of them last year. I personally think a gas spring/shock should last longer then 4 or 5 years. Under car hoods the last like 15 years...
            • NautiqueOasis
              • Oct 2005
              • 142
              • Dayton, OH
              Thx Surfsmith; that is very helpful. Also just noticed that the packing list from my new part states that the ML36-60 is a 17.2 inch 60 lb gas spring. It appears that 80 lbs should do the trick.
              '05 SV211 Nautique
              '97 Ski Nautique
              '90 Ski Nautique
              '85 Ski Nautique
              '79 Ski Nautique
              • Yiger
                • Feb 2013
                • 84
                • Maryland
                • 2013 Sport 200
                Mine works OK at best (2013 200v). It is pretty much just good enough to convince you to stick your head under it before it comes crashing down. Seems like a worthwhile upgrade...
                • Pjoachim
                  • Apr 2013
                  • 124
                  • Wisconsin
                  • 2001 CB ski
                  Mine has no issues at all. Maybe I got lucky.
                  Wisconsin
                  2001 196 Ski Nautique
                  2013 200V Team Edition
                  • sodbuster88
                    • Nov 2008
                    • 368
                    • Clayton, NC
                    No issues with mine either.
                    Peace..
