Truck parking brake hold while on the boat ramp?
  • jmo
    • Mar 2006
    • 707
    • MA
    Hey Guys,
    Just curious if a properly working parking brake should be about to hold my truck and ski boat on a reasonable paved ramp? Lately I have noticed after I set it the parking brake the truck still rolls back a bit, before I assume the parking prawl on the transmission catches? I tightened up the cable as my truck has 100k on it, could it be a sign my rear drum brakes are not working?
    Thanks,
    JMO
    2018 Ski Nautique 200 TE, H6
  • AirTool
    • 4049
    • Katy, Texas
    Fords should hold. Chevy's generally don't. Don't know about Dodge's.
    Generally, the problem is that your rear drum breaks need to be adjusted either with the manual adjusters or automatic adjusters (varies by vehicle). (New shoes do help.) Once you've done that, if it still doesn't hold, you need to adjust the brake cable.
    For some gm vehicles, the procedure to adjust is to back up hard and slam on the brakes and the adjuster will click. Some vehicles you pump the emergency brake pedal. You need to find the procedure for your vehicle and try it. Often it doesn't work and you have to pull the drum and adjust them manually.
    • jmo
      • Mar 2006
      • 707
      • MA
      Thanks Airtool, its a Toyota Tundra, in past I think it has worked better, I already tried tightening up the cable figuring after 7 years it had stretched... The rear drums have never been replaced.
      • AirTool
        • 4049
        • Katy, Texas
        Originally posted by jmo View Post
        Thanks Airtool, its a Toyota Tundra, ......
        Oops...forgot about those.
        Also, the back brakes set the pressure/resistance for the regular brake pedal if that makes sense. (In other words, the regular brake pedal cannot feel pressure resistance until the back brakes engage...then the fronts come on - although the fronts dominate after that point.) If you're system is properly bled (which it is) and your regular brake pedal goes all the way to the floor or farther down than normal, the back brakes need adjusting. They may also need replacing but even a very thin shoe liner can: stop the vehicle, provide a "good pedal", and set the parking brake. Often unadjusted shoes need replacing sooner than adjusted ones because the liner is only rubbing on the cylinder end and not the adjuster end. If you look at your shoes and see the liner is not a fairly consistent thickness along the entire shoe, that means they operated for a long time without proper adjustment.
        Besides the rear differential, (and maybe automatic transmission), rear brakes are the most neglected mechanical claptrap on a vehicle.
        • jmo
          • Mar 2006
          • 707
          • MA
          I actually change the rear diff (front & transfer case as well) and tranny fluid regularly as I plan on getting 250,000 miles out of it, it's at 101k now and still drives like it was new. The rear brakes I've never had to replace, in this case it turned out to be the pivots in the ebrake linkage that were rusted frozen and hence it won't engage.
          • Zach@n3
            • Sep 2012
            • 736
            • Indianapolis Indiana
            Drum brakes don't work as well when rolling backwards as they do forwards. Drums are designed so that the brakes wedge themselves into the drum as pressure is applied. If you want to test this set the parking brake, try to drive forward in gear, (probably won't move), try to back up in gear, (probably will move).
            My 10 ram will roll back just a little (disk rear brakes). If you park it on a hill with no trailer in just park it takes a lot of effort to remove it from park but with the brake on the ramp its easy to get out of park so I figure it helps quite a bit to have it on.
            • xrichard
              • Aug 2008
              • 669
              • El Dorado Hills
              • 2023 G23
              my experience with Toyota, including Tundra and Sequoia, is the parking brake does not do much. Confirmed by the dealer after I asked to have it adjusted and it still didn't do much...
              Previous boats:
              2015 G23
              2008 SAN 210
              2002 XStar
              1995 Sport Nautique
              • jbach
                • Aug 2012
                • 187
                • the state, not the jelly
                • 1999 SAN
                interesting. i have an 07 tundra and my wife an 06 sequoia. they will both hold the boat on the steepest of ramps in neutral with only the parking brake.
                • jmo
                  • Mar 2006
                  • 707
                  • MA
                  Now that it's fixed I definitely notice the difference, will report back once I launch the boat again.
                  • CCfan
                    • Sep 2010
                    • 13
                    Be careful on little used ramps covered in algae. The ramps can become so slick that submerged rear wheels won't hold the vehicle on the ramp. In that case, only a foot on the brake will hold the front wheels. Almost learned this the hard way earlier this spring.
                    • surroundsound64
                      • Jul 2005
                      • 2147
                      • Longview, TX
                      • 2018 230 1981 Ski Nautique
                      Both my Dodge's (2009 and 2012 2500s) hold well.
                      2018 SAN 230
                      1981 Ski Nautique
                      Sold - 2011 Sport 200V
                      Sold - 2000 SAN
                      • AirTool
                        • 4049
                        • Katy, Texas
                        My 99 tahoe doesn't hold - so at the steep ramp at Canyon,....I take chocks with me in case I need them.
                        My wife's old 99 navigator would hold but sometimes got pulled down w/the algae....mainly when launching.
                        On occasion, I had to leave my wife in the tahoe w/the truck idling in 4 low and the brake on.
                        • Yiger
                          • Feb 2013
                          • 84
                          • Maryland
                          • 2013 Sport 200
                          My '08 Tundra holds on the ramp... I imagine the level of use over the years would have an impact to some degree though.
                          • jmo
                            • Mar 2006
                            • 707
                            • MA
                            Hey guys - launched yesterday - holding solid on the ramp now the frozen pivots are fixed.
