Bilge pump stopped working
  • gvaldez3
    • Apr 2012
    • 54
    • Pearland, TX
    • 2007 Super Air 210
    The bilge pump on my 2007 210 super air stopped working. It wouldn't start up automatically or manually. Also, the manual button won't light up when I try to start it manually. What is the most likely problem? Thanks for any help.
  • Mamigacz
    • Oct 2012
    • 118
    • Sheboygan Falls, WI
    • 1986 Ski Centurion concourse skier
    It' most likely a fuse. The light and the pump are wired in parallel (they shouldn't fail together). I think if the pump was bad the light would still come on. If the fuse is good, you'll need to get the test light out and start tracking were the problem started from.
