HELP for 2006 SANTE 220 ballast pumps, Oil pressure light, and center Ballast
  • gsxrjtt
    • Jul 2013
    • 25
    • Tampa
    HI Have some minor fixes my 2006 SANTE needs
    1. When looking down into the engine bay from inside the boat the left ballast pump is fried.. WHats the best place to buy and how much should i expect to pay also the center is slow filling buy working any part numbers for that.
    2. I know i have oil pressure but the gauge is flickering but not going up. ???? any help ???
    3. The middle or center ballast light in the cockpit, gauge is working but it dosent light up ??? Help new bulb or gauge ?
  • s_kelley2000
    • 1575
    • Fort Meadow Recevoir
    • Mass
    What do you mean by the pump is fried? Does it do nothing when you try to empty or fill it? It could have tripped a breaker or I believe there is a relay for filling and draining that may have gone bad. If the pump needs to be replaced it is a Jabsco reversible ballast puppy that you are looking for. They range quite a bit in price but wakemakers.com usually has the best price on them which is $210 right now.
    For the slow filling center tank I would guess it could be a worn out impeller. http://www.nautiqueparts.com/impellerballastpump.aspx
    The oil pressure gauge could be a sender or a couple other things. There was a good thread about this recently if you do a search in the Maint section.
    The ballast gauge light is likely a loose wire connection or some other wiring issue.
    Shawn
    2012 Blue Metal Flake SAN 230
    • gsxrjtt
      • Jul 2013
      • 25
      • Tampa
      Thanks kelley great info.. Its little stuff but getting the boat ready for sale so this helps abunch
