New gauge is $400 from Nautiqueparts. I have one but have not installed it yet. I hope the replacement unit is sealed better. they seem very easy to remove, can anyone try re-sealing theirs after a good indoor dryout?
My gauge completely stopped working this weekend. Called and ordered a new gauge, $199 plus 38 shipping (ouch) will install this weekend. It sounds like the gauge has the wiring attached and you thread the wiring to the PP module and plug it into the module (vs plugging existing wires into the back of the gauge).
06 Ski Nautique 196 SE (2010)
99 Sport Nautique / GT 40 / FCT (2005 - 2009)
I have an '06 210 and have the same problem with my display. I contacted perfect pass, told them my symptoms and they recommended I replace the display. I ordered the display from them, $200 plus shipping and so on and I installed the display today. Works great, actually all the previous programming is stored in the gateway so when I plugged in the new display all the previos setting were maintained. As for install, its easiest to remove the 4 dash top screws, reach behind and remove old display. I the new display has a longer wire that goes directly to the gateway, which is behind the helm kickpanel. this requires removing the kickpanel (fuse panel/speaker panel) and attaching the new connector. Not difficult, some reaching while on your side under the seat, but not bad. Keep a few wire ties handy for replacement and securing the wires. My new display is much larger than the original and also much easier to read. On water test today too and seems fine.
My gauge was 199 plus 38 shipping (ouch). The display arrived, installed this weekend and works great. The one nice thing is the view or display area on the new gauge is much larger. Install wasn't to bad, 1 hour, wish I could have found a write-up. You get the gauge and the wiring is attached to the gauge, so everything is replaced right to the control unit. All the settings are in the control unit, so they are all fine.
