Hello! I have a '95 Sport that has an electrical drain problem. If the boat sits for more than a week, the battery is too low to start. I have replaced the battery. The alternator is working properly. It is a single battery. Nothing special or extra other than an aftermarket stereo. Faceplate is off. Ignition and everything else is off. The problem started last season. It worked fine for many years before that. Any tips or suggestions would be appreciated. Thanks in advance.
- Nov 2007
- 1575
- Fort Meadow Recevoir
- Mass
- 2012 Super Air Nautique 230 1999 Nautique Super Sport with 502 Python (for Sale)
When you say the ignition is off, do you mean the key or the ignition breaker button on the dash? Does the aftermarket stereo have an amp as well?Shawn
2012 Blue Metal Flake SAN 230
I would test for parasitic drain by disconnecting negative battery cable and putting a test light inline between battery and the cable. If absolutely everything is off light should be off. If something is pulling power then light will light. Then you can pull fuses to see if light goes off to use process of elimination to find if there is a circuit causing drain.
http://www.alpharubicon.com/bovstuff...almorpheus.htm
There is a lot of stuff on internet for looking for drain if that is what you want to do.
Do you have a battery switch? Could just turn it off (isolate battery) when not using boat.Last edited by scottb7; 07-26-2013, 11:38 AM.
Even a simple switch like this would allow you to keep battery from draining when not in use. Of course any automatic bilge pump won't run either.
http://www.autozone.com/autozone/acc...er=835218_0_0_
Originally posted by scottb7 View PostEven a simple switch like this would allow you to keep battery from draining when not in use. Of course any automatic bilge pump won't run either.
I'm guessing your bilge pump is coming on every little bit to check for water, it does that automatically. If it isn't shutting off I think that would be it. Do you have a bilge switch? If you replace the bilge pump and still have a problem, I would get a battery switch or a quick disconnect for it. Good luckNautiqueless in San Diego
I had this problem on my old 1995 Sport. It turned out to be a short in the temp sensor. It arced against something and caused it to slowly drain the battery. My mechanic discovered and repaired it during a routine maintenance visit. You might want to take a close look at all the wiring for something fishy.2017 G23
2012 210 TE
1999 SAN
1995 Sport
1991 Sport
Originally posted by maklen View PostThat makes more sense. I assume you were using a needle probe?
Thanks for all the good tips! I do have a Bilge Pump switch. Two in fact. One is manual and one is auto. Both are off. And I know the Bilge isn't coming on because it fills up (and stays up) with rain water. It is under a canopy, but a good sideways rain does sneak in. I did find a wire under the dash that had exposed wire. I taped that up with some electrical tape. Maybe the current was leaking out.
