2006 SANTE ballast problem!
  • Ksmit011
    • Jul 2013
    • 20
    • Ohio
    • 2006 210 super air
    I have a starboard ballast pump that won't drain! I have searched the forum and I know this is apparently an issue with the 2006 but I need more details on how to troubleshoot it. I pulled the pump out checked the impeller, (will replace with a new green one) it is not jammed and looks fine. I took the impeller out and ran the pump in fill and drain modes,,,the motor shaft only spins in the fill mode. I can hear a click under the dash when I push the drain button but nothing happens except the light blinks as it should. I read somewhere that the relays were located in the battery box, opened that up and activated drain on the pump but did not hear any clicking. I don't think the pump is bad because it works fine on fill...Where is the relay that sends power to the pump for draining??? Any help would be greatly appreciated!
  • jkallen21
    • Jan 2013
    • 399
    • United States
    • 2006 Super Air 220
    My 06 SANTE has breakers for fill and breakers for drain under steering wheel at driver's feet. This is in addition to the main breakers at the battery switch. Might start there. Just push the breakers to reset them.
    • jbarbee
      • Jul 2014
      • 11
      • INDIANAPOLIS
      • 2006 Super Air Nautique 220 TE
      I have and 2006 SANTE that I recently purchased and it also will not drain on the starboard pump. I hear the same clicking as you describe here. I have replaced the ballast controller and the starboard ballast sending unit. I also think this is a relay issue as my pump will fill. Do you recall how you solved this issue?
      • d_nodixon
        • Sep 2008
        • 475
        • Hammond, LA
        • 2013 SAN 230
        my experience: tripped breaker equals stuck impeller(black)
        won't empty was level gauges reading empty because of loose connection
        Sent from my C771 using Tapatalk 2
        2013 SAN 230
        2006 SSN 210 (SOLD)
        • 1955 classic
          • Apr 2013
          • 39
          • New Zealand
          could be relay or motor or sender unit or stuck(tight impellor) blowing the circuit breaker
          if the sender in the tank is faulty, it will allow you to fill the tank, but not drain. had this happen to me. At least you have replaced yours
          you can check the motor by unplugging it and reversing the polarity of the wires, if it runs in both directions , motor is okay.
          to check to see if you have voltage when it should be running, unplug ballast pump, and see if you have 12v at the plug connection
          Not sure on the type of relays, but if its a basic automotive unit, under $10 should have you fixed
          anything else, i dont know sorry,
          • mt92
            • Jun 2014
            • 23
            • Kirkwood Il
            • 2006 SV-211
            I am having the same problem with my 2006 SV211 the pump will fill but is very picky about when and how long it will drain sometimes. I have the se with the keyed ignition and only fuses I believe. LMK if you find what is causing your problem.
            • 1955 classic
              • Apr 2013
              • 39
              • New Zealand
              sounds like the issue i had with my sender, fills fine, but empty would be very eratic ( 4-10 minutes)_ and sometimes not at all. easy test, swap the senders in the two tanks and ifproblem goes to other tank, then replace the sender.
              The magnet material which slides up and down the sender, seems to break on the inside giving eratic readings
              also as the motor would stop and start, the gauge would flicker and give a reading, then nothing
              • d_nodixon
                • Sep 2008
                • 475
                • Hammond, LA
                • 2013 SAN 230
                can also unplug and insert a jumper wire rather than swapping senders
                2013 SAN 230
                2006 SSN 210 (SOLD)
                • jbarbee
                  • Jul 2014
                  • 11
                  • INDIANAPOLIS
                  Thanks for all the ideas. I will try them and see what I can find out this coming weekend. I have not tried reversing the polarity on my starboard pump, but I will do that and check voltage to make sure it works in both directions. Has anyone ever had the impeller be the issue that would stop the pump from spinning one direction. FYI I have not had any breakers tripping, at least not yet.
                  • jbarbee
                    • Jul 2014
                    • 11
                    • INDIANAPOLIS
                    Okay, I finally got to test things a little more. Here is my status. Port, Startboard, and Belly pumps will all fill the ballast tanks. Only the port and belly pumps will empty. As an experiment, I swapped plugs on the pumps and moved the belly pump connector to the starboard pump. After doing this, the starboard pump will fill and dump without issue. I also tried plugging the starboard pump connector into the belly pump. The belly pump would then fill, but not dump. Any other ideas?
                    One other piece that I think maybe related to my issues. When the power is off, all ballast gauges read empty. As soon as power is applied, my starboard pump gauge reads full. This is the same one that I replaced the sender on. The odd thing is it will let me fill the tank, it just will not dump it. More ideas welcome.
