Squeaky Belt
  • BIGAIRCPA
    • Sep 2012
    • 64
    • Illinois
    Squeaky Belt
    Hello -
    i need some help..I get, from time to time, a squeaky belt when I start the boat. After driving for 5 minutes, I don't hear it for the rest of the day and weekend. Any idea on how to fix or tighten the belt? I am no that mechanically inclined but I have a brother who is.
    Thanks for the help in advance.
    Phil
  • Neverenough
    • Sep 2012
    • 907
    • Ft. Worth Texas
    • G
    Depends on year and model of engine.
    • jbach
      • Aug 2012
      • 187
      • the state, not the jelly
      • 1999 SAN
      Id recommend you watch your brother check the belts so you can do it next time, or possibly even replace it after it snaps. If pumping gas is a 2 out of 5 on the difficulty scale, belt maintenance is a solid 2.5. It's also in the manual.
      • BIGAIRCPA
        • Sep 2012
        • 64
        • Illinois
        It's a 2012 ZR450 in a SAN230.
        • AirTool
          • 4049
          • Katy, Texas
          When I have a squeaky belt, I spray a little oil on it while the engine is running. Maybe some Remington gun oil or other stable lubricant.
          Don't make a mess...it only takes a quick blast on the grooves....maybe with the red extension tube on the nozzle.
          Never use silicon or "belt dressing"....in my experience, that just makes it worse.
          ps - on that engine, there is no belt tension to adjust.
          • hotstreetvw
            • Apr 2008
            • 24
            Could be your idler pulley bearing going out. I had a similar issue, went to autozone, looked up a similar GM 5.7 (PCM 330) and it took all of five minutes and $20.
            • Neverenough
              • Sep 2012
              • 907
              • Ft. Worth Texas
              • G
              Tool you are right! I have a little squeak so I hit the alternator and idler with some spray oil. Then fired it up hit the belt with dressing and it was twice as loud. Headed to parts house and got a new idler and belt. Will see what happens. BTW 343 idler pulley is a Gates 38009. About 18 bucks.
              • Neverenough
                • Sep 2012
                • 907
                • Ft. Worth Texas
                • G
                New idler pulley new belt no squeak. Bigair as new as your boat is I bet you just need a touch of oil like tool says.
