1984 Ski Nautique 2001 need a new harmonic balancer
  • 510boat
    • Aug 2013
    • 7
    • Niles, Il
    • 1984 Ski Nautique 2001
    Hi! I have a 1984 Ski Nautique 2001 with a Ford 351 Windsor. The harmonic balancer spun in the rubber. It hasn't been easy trying to find a replacement. Most of the aftermarket or performance ones are all four bolt patter for the pulley instead of three. I would like to find one that has the same backspacing and everything so the pulley will line up. The couple I have found that look similar are out of econoline vans or old muscle cars. They just don't have the dimensions or crank end id and od. Some are listed for different engines. If anyone knows a place or has a part number that would be great!
    Thanks,
    Charlie
  • s_kelley2000
    • 1575
    • Fort Meadow Recevoir
    • Mass
    Checkout Discount Inboard Marine (skidim.com), they are pretty good about tracking down hard to find parts. I'd also post this question over on correctcraftfan.com, there are a lot of SN 2001 owners over there and they should be able to point you in the right direction or maybe even hook you up with a used one.
    Shawn
    2012 Blue Metal Flake SAN 230
