2007 SV211 Perfect Pass
  • OKWAKEBDR
    • May 2005
    • 750
    • Lakefront
    • 2017 Super Air Nautique G23
    Out with my parents a few weeks ago and their perfect pass was not working properly when pulling me wakeboarding. The perfect pass would "beep" as if it was engaging, but it would just continue right through the set speed.
    I'm the only wakeboarder - the rest of the family skies using rpm mode, and they didn't have the problem.
    When did Nautique go to Throttle By Wire in the 211?
    The FAQ section of the "non-throttle by wire" manual on perfect pass's website says that the Servo Motor may not be spooling correctly, and needs to be tested, or possibly replaced.
    Any ideas?
    Current: 2017 G23
  • layneherring
    • Sep 2011
    • 16
    • Lake Keystone, OK (Tulsa)
    • 2007 SV-211 TE ZR6
    2007 SV-211 with ZR6 and have been having exact same issues. Mine is drive by wire so think your 2007 is as well. Monday night I really experiemented with wakeboard settings on Perfect Pass. Speed would go through the set zone and go 5 mph over, also experienced much "surging". Seemed to behave better as the evening went along. I brought my manual in from the boat, studied it, and now feel I need to adjust the sensitivity setting on Perfect Pass. May be a week before I get to play with settings but you may want to read up and see if it sounds like your issue since RPM mode works fine for you.
    • OKWAKEBDR
      • May 2005
      • 750
      • Lakefront
      I tried that. It didn't help.
      Current: 2017 G23
