The PO removed the factory heater after a core leak. He just put in an elbow to return the flow and left everything else in place. I see Heater Craft gives a 30% discount which is awesome, so looking for the biggest heater that will fit in the stock location as well as options routing additional lines. Thinking about running a solid piece of PVC from the heater to the back tucked under the gunnel rail if that's possible and won't lose too much heat. Looking at the 300 but don't see any dimensions on their site?
I believe Nautique generally puts in a 2-outlet heater, then uses a Y connector to split one of the outlets to run up to the dash as a defroster. Not sure if the 3-outlet you're looking at will fit in the stock location.
Call HeaterCraft and tell them you saw their ad here and see what they recommend. 1 (208) 687-4400I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
