got my new to me 2006 SANTE yesterday all the way from AZ to New Zealand
can anyone help with the following please
I have charged the batteries, and cannot get any accessories or starting to work on the start keypad except the bilge pump and air blower.
The background lighting lights up on the keypad, but when i push the start button there is nothing. the numbered buttons from 1 to 10 seem to work as a light comes on
I am thinking either it has a bad keypad or it is keypad number locked. I did ask whether it had a lock number and was told it did not
what i have done and found below
main earth/ground connections on engine very loose - tightened
main starter motor positive cable very loose - tightened
positive feed wire on the back of the circuit breaker board at the drivers feet was very loose- tightened
drivers safety lanyard switch is operating correctly, pulled wires and checked on multimeter beeping continuity
batteries charged and tested for load
battery terminals cleaned.
battery switch set for both batteries or one, or two, doesnt change anything
switch at drivers knee area is 'All on' and wiggled it whilst repeatedly trying the start button. will check this tomorrow on terminals on back of switch with multimeter
in short, i press the start button and nothing happens, It will not even enter accessory mode
any help would be greatly appreciated, also what is master code in case it has a lock on it
