When the boat is in the water and not in use (at the dock),which switches have to be in on position?
Ignition?
Bilge Pump?
Does the Perfect Pass take enough power when in on position to empty the battery?
I had the ignition on, bilge pump on and the switch for the Perfect Pass on; after 2 days, my battery was empty. Is this normal, do I have to leave all these in the off position....or is there a prob with my battery?
It's a 12V 74A/h
Which batterie do you have on your boats?
Ignition?
Bilge Pump?
It's a 12V 74A/h
