3 position bilge switch replacement
  • sfjakey
    • 208
    • SF Bay Area
    • 2015 230 ZR6
    Ok, I've bought the replacement switch from Nautiqueparts.com, and now I am wondering how to change the wiring to make it operate. The original switch had 2 hot wires soldered to it in the center, one for ignition and one for bilge, depending on switch position. So it was 2 hot leads and 2 load wires. The new swirth has only 3 positions on the back, so I assume I abandon the hot lead from the bilge side? Right now, I have both spliced through so I can continue to use the boat. What have those of you who upgraded this switch done to deal with this? Thanks.
  • sfjakey
    • 208
    • SF Bay Area
    • 2015 230 ZR6
    Nobody has replaced this switch? How did you deal with the 2 hot leads?
    • mbaumet
      • Sep 2012
      • 54
      • Liberty Township, OH
      • 2018 Super Air Nautique 230
      switch=sfjakey;211897]Ok, I've bought the replacement switch from Nautiqueparts.com, and now I am wondering how to change the wiring to make it operate. The original switch had 2 hot wires soldered to it in the center, one for ignition and one for bilge, depending on switch position. So it was 2 hot leads and 2 load wires. The new swirth has only 3 positions on the back, so I assume I abandon the hot lead from the bilge side? Right now, I have both spliced through so I can continue to use the boat. What have those of you who upgraded this switch done to deal with this? Thanks.[/QUOTE]
      I have. Check out the below thread. I posted pics in this thread. I changed to the same switch from nautiqueparts.com. FYI, my boat is an 06 210 San. Let me know if you need more info.
      http://www.planetnautique.com/vb3/sh...ghlight=switch
      2018 SANTE 230 - H5
      2006 SANTE 210
      • mbaumet
        • Sep 2012
        • 54
        I have. Check out the below thread. I posted pics in this thread. I changed to the same switch from nautiqueparts.com. FYI mine is an 06 210 san.
        2018 SANTE 230 - H5
        2006 SANTE 210
