oil pressure switch
  • shonuff
    • Sep 2010
    • 157
    • Atlanta, GA
    • '05 SANTE
    oil pressure switch
    Yesterday in my 2005 210 the check engine light came on and went into limp mode. The temperature was good and oil pressure read 40 psi at idle. After some research, I decided to disconnect the wire to the oil pressure switch. The check engine light went off and boat returned to normal.
    The oil level was a little low but I still had 40 psi at idle. Does anyone know what pressure triggers the oil pressure switch to turn on the check engine light and if my oil pressure was at a normal level? The manual says normal pressure is something like 25-60 psi which doesn't help. I want to make sure the oil pressure switch is bad before ordering a new one.
    2005 SANTE
  • Mamigacz
    • Oct 2012
    • 118
    • Sheboygan Falls, WI
    • 1986 Ski Centurion concourse skier
    -Unplug the harness to the switch.
    -Get a multimeter and toggle the settings for checking resistance (OHM's).
    -Measure the resistance across the pressure switch poles when the engine is off.
    -Then measure the resistance when the engine is on.
    If nothing changes from on to off, the switch is bad.
    I hope this helps
