Want Start...need help
  • rocco
    • Jan 2004
    • 167
    • Virginia
    today I was out on the lake..pulling a skiier..
    she fell,,so I cam around to pick her up....
    I cut my boat off then back on real quick....and it would'nt start..
    its a 502 chevy.....Its a Fuel injection too...I have check everything I know of.....its not getting any fuel....whats going on,,,is it a easy fix I hope...And it the Holiday weekend...any body had this happen..
    Rocco
  • Baken
    • 45
    • WA
    RE: Want Start...need help
    If your not getting any fuel, I'd start with the fuel pump.
    • rocco
      • Jan 2004
      • 167
      • Virginia
      Well,,,,I just figured,,it would be a quick fix...This (EFI)..
      maybe a reset switch or something....Its like a diesel motor when it runs out of fuel,,,,,But what do you do,to get it going again...
      can you prime it or what..................
      • rocco
        • Jan 2004
        • 167
        • Virginia
        OK.......got it fixed last night...after about 4 hours of tracing wires to see if they where hot or not...found the problem...the ground wire from the electric fuel pump to a relay fuse was burn into..(inside the coating).
        without an amp meter...the problem could have when on a good while...
        R
