I need some ballast!
  • Treeman226
    • Jun 2013
    • 1
    • GA
    • 2004 226 LE
    I recently bought a cream puff '04 226 limited. The boat has port, starboard, and center ballast switches/fill gauges as well as outlet ports (I don't know where to look for inlets). However, the factory hard tanks were never installed. Neither were pumps or cutoffs switches. I really don't know much about the system, but I need some weight in the rear lockers and center locker. I know the gauges are probably a no go, but I really want to hook up to the existing fill/drain switches if possible. Also, does anyone know how big of a sac will fit under the walk thru transom? Any advice is greatly appreciated.
