1997, GT 40, 500 hours. Starts great but after it runs for 20 minutes, it develops a cylinder miss. I have all new wires, Ohm'd out all the injectors cold and after running and all were within tolerance, also used a snap on tester to check the injectors under stress and all worked the same. You can smell the raw gas out the exhaust after it starts missing. Any help or idea's would be appreciated.
