Has anybody that has changed oil in a 550, had any problem inserting the suction tube down the dip stick tube, same suction machine I have used for all my passed boats but for some reason suction tube hits a resistance about 3/4 down ,will not let it go pass??
A d m i n i s t r a t o r
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
I hooked up my suction tube to the factory drain hose. Works great there.
Sent from my iPad using Tapatalk HDI own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Jeff, is it easier to get to port or starboard, also I thought there was a valve ,when turned the oil came out on the factory drain hose or are you pulling high above engine and then inserting hose ?? thanks2013 G23 super air
2010 230 super air
2009 220 super air
2008 210 super air
2005 210 super air
2003 calabria pro air
- Mar 2002
- 16519
- Lake Norman
- Mooresville, NC
550 oil change
No valve on mine. I just pulled it up above the engine and pumped it out. Mine was on the starboard side.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
