I am just curious about an issue that folks tell me is my starter. I push the keycode, and start button and I get a single "click", push and hold, not turning over. Then after multiple pushes and clicks it will finally turn over. All connections were tight. I just removed the starter and my problem/concern and paranoia is if it is the starter - is there any sort of cross reference or anything. I am in the normal situation of needing the boat for the weekend and running out of time, any help is appreciated. Thank you in advance.
Order this, use the PlanetNautique Discount (PND), and have them ship overnight if necessary. DO NOT buy a non-marine starter!!
http://www.nautiqueparts.com/startergm.aspxI own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Starter or starter relay. On the GM engines, I don't think you can replace the relay separately from the starter though. You can on the Ford starters, but the relays on the GM starters are built in.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
First make sure you have a fully charged and fully functioning battery.
Then....make sure the click is coming from the relay/solenoid on the starter. If it is, the starter is bad. It sounds like a bad spot on the rotor or stator. When it lands in that spot, it won't crank. When it lands in a good spot, it works.
I took it to an Electrical fella who tested the starter/solenoid and said the solenoid failed multiple times. In about 10 minutes he took it apart, pulled some parts off the shelf and gave it back. 35.00 later I installed it and it works perfectly. THank you everyone for your help.
That's awesome! Can't beat that!I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
I had the bad contact issue within the perko switch, showed the same problem in my 2002. very frustrating until I calmed myself down and started following from the battery back.Eric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
Is the relay sealed inside the newer GM starters or is attached to the outside and need to be a marine rated solenoid? Just hoping the OPs starter is still marine rated after the fix. If its sealed inside then I think it's ok. If its attached on the outside you should make sure a marine solenoid was used. Im glad this fixed your issue, just want to make sure it's a safe fix.Shawn
2012 Blue Metal Flake SAN 230
Originally posted by s_kelley2000 View PostIs the relay sealed inside the newer GM starters or is attached to the outside and need to be a marine rated solenoid? Just hoping the OPs starter is still marine rated after the fix. If its sealed inside then I think it's ok. If its attached on the outside you should make sure a marine solenoid was used. Im glad this fixed your issue, just want to make sure it's a safe fix.
1. Not sure about the sealing/marine spec and
2. Repairing actual components seems to be a lost craft.
