2013 G23 Starting Problems. Sounds like dead battery but must be electrical
  • fatchance720
    • May 2013
    • 75
    • Olympia, WA
    • 2013 G23 450 2011 Axis A20
    I got back from vacation, I had my boat detailed. I accidentally left the batteries on (only 24 hours from last start) and I launched the boat in the water and I pressed start twice waited for the system to boot up then the 3rd time hitting start all I got was a click like a dead battery. I tried a few more times then gave up and trailered home to charge. 5 Hours later I tried again and same thing. This time a electrical smell? Any chance when getting the boat detailed a wire got knocked loose on that yellow box under seat behind driver? I wondered if a ground wire got loose. The person detailing the boat did not go into where the battery terminals were. I checked both batteries to ensure the connection was tight. It is supposed to be 80+ all week and my dealer is 2 hours away and I do not even own a truck. Anyone else encountered a problem like this?
  • JamesHawk101
    • Dec 2012
    • 224
    • Indian Rocks Beach
    • 2015 G23 Coastal
    Sounds like a bad starter. Does the screen boot up and everything?
    2015 G23 Coastal Edition 450 NSS
    2013 G23 Coastal Edition 450 NSS
    • ers906
      • Feb 2010
      • 921
      • Phoenix AZ
      Was it a click and did it sound like the engine tried to turn over, or just a click like the stater solenoid?
      Eric, Phoenix AZ
      G23 550 hp (finally here)
      2002 Super Air
      • vision
        • 515
        • NC
        • 2013 G23
        My question as well. Screen/computer booted? If so, simply swap out a battery for a fresh one and see if it cranks. Use just one battery on the perco battery switch. This would at least tell you if it was just battery versus bad ground/lead wire/solenoid/starter.
        • fatchance720
          • May 2013
          • 75
          • Olympia, WA
          No Way it can be the battery, volts look good, screen boots up fine. It did flutter once. I think it has to be a short somewhere. I am getting my surf pipe installed anyway so fortunately my dealer is picking my boat up and they can check it out.
