Does anybody have info on a 537 prop, what kind of a prop is it ?
- Nov 2007
- 1575
- Fort Meadow Recevoir
- Mass
- 2012 Super Air Nautique 230 1999 Nautique Super Sport with 502 Python (for Sale)
The 1579 is a 13.5 dia x 14.25 pich x .150 cup. In general the lower the pitch number the faster it will come out of the hole and the more weight it will be able to get on plane but the sacrifice is going to be higher RPMs and a lower top end speed. Depending on how much ballast you are running you may struggle to get on plane with a 537. If you are going to be cruising around on a big lake you will be able to cruise at a lower RPM with the 537 and should get better fuel economy.Shawn
2012 Blue Metal Flake SAN 230
