537 Prop
  • Calgary210
    • Oct 2010
    • 45
    • Calgary
    • 2011 SANTE 210-Sold 2008 Malibu VLX - sold
    537 Prop
    Does anybody have info on a 537 prop, what kind of a prop is it ?
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    ACME makes the 537 prop. Its a 13.5 dia x 16.0 pitch x .105" cup 4 blade Nibral CNC prop with a 1.125" tapered bore.
    • Calgary210
      • Oct 2010
      • 45
      • Calgary
      How does it compare to my 1579 on my 210
      • s_kelley2000
        • 1575
        • Fort Meadow Recevoir
        • Mass
        The 1579 is a 13.5 dia x 14.25 pich x .150 cup. In general the lower the pitch number the faster it will come out of the hole and the more weight it will be able to get on plane but the sacrifice is going to be higher RPMs and a lower top end speed. Depending on how much ballast you are running you may struggle to get on plane with a 537. If you are going to be cruising around on a big lake you will be able to cruise at a lower RPM with the 537 and should get better fuel economy.
        Shawn
        2012 Blue Metal Flake SAN 230
        • Calgary210
          • Oct 2010
          • 45
          • Calgary
          Thxs for the info
