05 210: i currently have wedge sacs plumbed on top of the factory tanks. can i just remove the hard tanks and drop in 750's with the OEM hose configuration? Do i HAVE to reinforce the dividers, and if so, what's the simplest/best method to do this. thanks.
'05 still has aerators right?
If so, you should be able to just swap out the tanks for 750's and if you want to add an inline valve to back up the seacok you can do that at the same time.
what are you using up front for weight?
P.S. I'm trying to get my buddy with an '04 to do this now before it gets cold and we have to fight those tanks to get to the water drains on the block.Last edited by crobi2; 10-04-2013, 10:25 AM.Rob
2000 SAN
yes still one drain and one fill aerator pump for each tank. i usually run the triangle sac aka integrated bow sac up front, with about 100-150 in lead up there on the port side. then we run either a 400 on the floor in the cockpit area or if it's just me and my buddy we throw his full size bow sac on the floor. i probably won't add a valve since i already have the open/close valves under the dash(that work) and the seacocks if something happens, plus a tsunami or two onboard always as well.
