I am having issues with my steering. It is very hard to steer to the right and the boat has been taking on water while underway. I filled the bilge with water and found a leak through one of the screws holding the rudder plate. I just noticed that the backing plate inside the boat is cracked. Has anyone seen or dealt with this problem. I did some research online and found mixed comments. Some said it is fine because the plate is acting like a washer. Others have said it absolutely shouldn't be cracked. Any insight would be great. Thanks for your help
Rudder Problem/Question
I am having issues with my steering. It is very hard to steer to the right and the boat has been taking on water while underway. I filled the bilge with water and found a leak through one of the screws holding the rudder plate. I just noticed that the backing plate inside the boat is cracked. Has anyone seen or dealt with this problem. I did some research online and found mixed comments. Some said it is fine because the plate is acting like a washer. Others have said it absolutely shouldn't be cracked. Any insight would be great. Thanks for your helpTags: None
- Mar 2002
- 16454
- Lake Norman
- Mooresville, NC
Yes, your rudder port backing plate is in poor condition. You should replace that as soon as you can.
http://www.nautiqueparts.com/rudderport.aspxI own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
Originally posted by NautiqueJeff View PostYes, your rudder port backing plate is in poor condition. You should replace that as soon as you can.
It seems strange to me that such a soft material would crack like that.
Anywhoo...time to replace.
Agreed. Time to replace it. While you have the steering cable disconnected, turn the wheel all the way, stop to stop. Does it feel kinda stiff? If so, go ahead and replace the steering cable while you're there. If not, you'll be taking all of this apart again soon to replace it anyway...
-Charles
I have seen that before... what year is your boat? I suspect there may have been some bad castings.
To suggest that the whole port needs to be replaced is ridiculous. That plate is in fact just a fancy washer. I'd see if you can buy just the backing plate separately. If not, I'd seriously consider using it as-is with some fresh sealant (3m 4200 or similar).1990 Ski Nautique
NWCT
Mine has had the cracks for three years (since I bought it) and not a leak or problem yet. I don't think it affects the stability of the rudder or compromise the safety. It appears to only be a back up plate for the fasteners that hold the rudder plate through the hull and is simply to spread the pressure evenly on the hull. But, I could be wrong and need to replace mine too. Depends on "what the experts say". Very curious to see if any others chime in.2005 SV-211
Mine has the cracks too (2005 SAN210TE), but my steering works very well. I did not see copious amount of water coming in from the backing plate. Mine looks like it has not shifted as much as yours has. Perhaps the backing plate is dragging on the rudder shaft more in one direction of rotation than it is in the other, requiring more force when turning right, or you may want to check your steering cable. This is what mine looks like.
Thank you for all the replies. The boat is a 2003 super air. I disconnected the steering and turned the wheel in both directions and it is very smooth. I think the problem lies in the rudder. I am going to try and make my way to a local boat shop that works on nautiques and see if they have anything to say about the cracks. I do like the new rudder port because it has a zirc fitting which would help keep the rudder shaft lubricated! I will post any information that I get from the shop. Thanks again
08 220 cracked also. No leaks no rudder issues. It's been kinda bothering me that's it cracked but I'm not sure that replacing it is worth taking it apart.
I maintain my Air meticulously. In 13 years, I've never been stranded, never been towed home. It's never let me down because I've never let IT down. We've all heard the expression about a boat being a hole in the water where you throw money. I know boats CAN be this but they don't have to be.
There are two types of maintenance you do on a boat:
1) Preventive
Or
2) Disaster Recovery
Pick which one you want. Preventive is all about being proactive. Spot small problems before they become big ones. Be diligent. Don't get behind. Disaster Recovery is all about being reactive. Let it go to the point of failure and deal with it then. Personally, I can't see how anyone would think it would be better to wait until it fails, but those are the same people that smirk at me.
-Charles
Spoke with the boat shop today and the person I talked to said the cracks probably resulted in sharp turns under heavy speed. I have owned the boat for a few months so I have no idea how the previous owner drove the boat. He said a new backing plate was around 50 dollars. I plan on replacing the whole unit because I like the idea of having the zirc fitting. I have read numerous threads where people wished they had the fitting so the rudder could be lubricated. Thanks for all the replies. I will try and take some pictures and give some feed back on how the new install goes. Thanks again!
- Sep 2012
- 736
- Indianapolis Indiana
- 1986 2001 ski nautique 68 correct craft skylark
I almost bet the bed that the backing plate lies on is not 100% flat and if you install a new one it will crack as well. Like Tim said it's just a big washer and if it retains bolts it will be fine. There should be no way that would crack under heavy turn loads. that piece isn't the load bearing piece of the mechanism. The port itself bears the rudder load and that is distributed onto the rudder port pad where it mounts from the bottom. If something is flexing enough under turns to crack that backing plate then you have way bigger problems than that. Question your shops knowledge on that.........I included some pictures of a removed port. The backing plate is free floating and doesn't make a machined surface contact with the port bore. See pictures.[EMAIL="Zach@n3boatworks.com"]Zach@n3boatworks.com[/EMAIL]
You may want to consider adding a grease point to your existing rudder, labor would not be much different and you save quite a bit on the part. Not sure how accessible that rudder is on a VDrive, if it's a PITA to get at you could also add a hose to a remote Zirc similar to what the factory does now.
