Alright everyone, here's one for you. I have a 95 Ski Nautique closed bow, with a GT-40 only 548 hours. Just near the end of the year i noticed only after the boat sat for a long period after use it had a small oil drip. It is coming from between the engine and transmission bell housing. I wipe it up before hitting the lake and there is no oil drip after the day on the lake but again after sitting for the week it has a spot under the engine. It is definitely oil. The longer it sits the bigger the oil spot.
So my question is, where is it coming from. My only 2 thoughts were either the rear main or the oil pan gasket. But with it not leaking while in use like a day out on the water and only on trailer sitting i am leaning towards the oil pan gasket.
This is very frustrating because I baby the boat and find this.
Any thoughts and input is going to be greatly appreciated. Also any advise or experience with puling the motor to fix either problem will be greatly appreciated. Thanks for reading and thanks in advance for the help.
