Hi all,
Had the boat out last week end and it developed what sounded/felt like an ignition misfire. It only did it once, for a period of about 5-8 seconds whilst under full load getting onto plane. It hasn't done it before and didn't do it again, we used the boat for approx 1.5hrs run time there after.
I don't see many misfire related threads on here which tells me the ign systems are generally fairly reliable and indeed the plugs appear to be the original set (41-993) and same goes for the leads. I pulled a few plugs and all looked OK. Boat has 260hrs on it.
My question is, is there somewhere else I should be looking? do the HT leads wear/fail?
It certainly didn't feel like a fuel supply problem as it still pulled out with 3500lbs+ of ballast and people. Power didn't noticeably drop while misfiring and sounded like only one cylinder was to blame.
any ideas?
any ideas?
