A buddy of mine has a 2003 SAN 210. He had a friend help him winterize it but he said he only drained one side of the block. The other side (port side) they did not drain. In all my years of winterizing boats, I've always drained both sides of the block. He did drain the exhaust manifolds, the water pump, strainer, etc... He didn't drain the v-drive either... I helped him do that last night. Can you tell me if he needs to pull the plug from both sides? Thx.
This is an excellent guide to follow. Please be sure to read the additional posts after the OP.
http://www.planetnautique.com/vb3/sh...N-EX330-photos
When I bought my 86', the first few years I would drain the block and manifolds then run the RV AF through. around 4 gallons or so. Then I realized I was wasting time draining the water first. I now simply run 4 - 5 gallons of RV AF through and never had a problem in 10 or so years. The AF flush is replacing all the water so why bother draining it? And the winters get pretty frigid in Pittsburgh.
Originally posted by scott resick View PostThen I realized I was wasting time draining the water first. I now simply run 4 - 5 gallons of RV AF through and never had a problem in 10 or so years. The AF flush is replacing all the water so why bother draining it? And the winters get pretty frigid in Pittsburgh.
So for any new winterizers, "BEWARE OF THE ABOVE ADVICE".
I went the other direction. I drain by hand, and from here on out am skipping the pink rv antifreeze. That way I can get up close and personal with engine once a year to check things out, and save $ and effort with rv antifreeze, and worry that it might not get everywhere in semi warmed up engine. Manual even states to drain first and then use antifreeze as an additional option.
Also that link shows teflon tape being used on knock sensors. I thought people on this site said that was a "no no"?
I drain by hand, and from here on out am skipping the pink rv antifreeze. Also that link shows teflon tape being used on knock sensors. I thought people on this site said that was a "no no"?[/QUOTE]
I like the thought of my impeller, hoses and other rubber seals and parts bathing in AF while in storage. That would be my only issue with this plan.
