Tricks for getting out a semi-rounded exhaust drain?
  • kapieyow
    • Oct 2013
    • 3
    • United States
    I did a little searching and didn't find anything. Does anyone have any tips for getting out a semi-rounded exhaust drain plug? Was partially rounded by the PO, then I made it more roundy. Still has some edges. This is on a gt-40. The drain is a square 5/8s. Seems like a 8 point box end would be perfect but doesn't look like anyone makes those. 8 point socket won't fit with out taking the exhause hoses off. I have tried deep creep and then some light heat. No dice.
    Any tips will be appreciated.
  • shawndoggy
    • Aug 2011
    • 151
    • Reno
    • MB Sports TWB 23
    vice grips and then buy a new one?
    • j2nh
      • Dec 2003
      • 628
      • Spread Eagle Wisconsin
      More heat. Give it some taps when it is hot to see if you can break it free.
      Anyway you can get a pipe wrench on it?
      My brother had one stuck on his Mastercraft and he had to get it red hot to get the plug out. Once it is out replace it and don't forget to use liberal amounts of anti-seize.
      2018 200 Team H6
      2009 196 Team ZR 409
      2005 196 Limited ZR 375
      2003 196 Limited Excalibur
      1999 196 Masters Edition
      1987 ProStar 190
      • vision
        • 518
        • NC
        • 2013 G23
        Second small pipe wrench. They work well on softer metals like brass.
