2005 Air Nautique Wont Start
  • strots01
    • Jul 2012
    • 5
    • Ohio
    • 2005 Air Nautique 226 TE
    So I have a 05 226 Air Nautique that has been giving me problems starting. It is an intermittent problem that started in June. I replaced the Fuel relay in June and after that have had absolutely no issues until now. I now punch the code in, the perfect pass powers up, none of the gauges power up, the starter turns but the boat doesn't fire. I swapped out the 3 relays on top the motor next to the computer but nothing. I can hear a clicking noise from what seems to be coming from the computer, but not sure? The fuel pumps to not seem to always kick on either but I can smell fuel when turning over? Thoughts on where to start? Am I having fuel pump issues or computer?
  • Quinner
    • 2245
    • Correct Crafts
    Check or bypass the lanyard
    • strots01
      • Jul 2012
      • 5
      • Ohio
      Thanks for the advice. Did just that tonight and still the same issue? Any other ideas?
      • ski4evr
        • May 2010
        • 613
        • Bowling Green, KY
        • 2005 SV 211
        PCM MEFI Manual.pdfNot sure if this will help, but page 199 table a-3 has a good trouble shooting table to track the problem down without a lot of guessing. A ton of good information in here. Good luck.
        2005 SV-211
        • cguse13
          • Aug 2012
          • 96
          • Broken Arrow, Ok
          Have you checked the grounds??? I had similar random non starting issues one the water last summer and it turned out to be a loose ground wire.
          2005 Nautique 210
          96 Mastercraft Prostar 205
          94 Malibu Euro f3
          • rbalan
            • 328
            • Georgia
            • 2002 SANTE
            Not sure about 05 models, but 03 and earlier models have an inline fuse close to the battery that will go bad and lose power to gauges.
            • strots01
              • Jul 2012
              • 5
              • Ohio
              Seems as though it was a loose wire on the harness leading to the fuel relay. Tightened up and works great! Thanks for the tips guys!
