2013 g23 impeller questions
  • davidmamato
    • Oct 2013
    • 44
    • westminster, ca
    Just got our G23 and need to know where the impeller is located.
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    depends on what engine you have. Look in your owner's manual or go to the PCM website and look up your specific engine. That'll take you less than 2 mins to get it that way.
    But likely its on the back side of the engine towards the transom.... its part of the belts/pulleys.... it should be the only item back there with two of the big 1.5" hoses running up vertical in and out of it.... 1 coming stright up to it and then the other coming straight down, approx 1/2" apart.
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • davidmamato
      • Oct 2013
      • 44
      • westminster, ca
      2013 g23
      pcm 450 motor
      • AirTool
        • 4049
        • Katy, Texas
        depends on what engine you have........
        pcm 450 motor
        .....Look in your owner's manual or go to the PCM website and look up your specific engine. That'll take you less than 2 mins to get it that way.
        Welcome to the site.
        • thedude
          • Apr 2007
          • 451
          • SW PA
          Starboard side of engine, you will see hoses/belt attached to it.
          • davidmamato
            • Oct 2013
            • 44
            • westminster, ca
            thanks dude
