Throttle / fly by wire problem
  • aZ`
    • Apr 2013
    • 154
    • Australia
    • 2008 210
    Hi, I did a search but couldn't find anything so..
    Has anyone else has any dramas with your throttle in a FBW model?
    On the weekend, The boat was OK to begin with, but when we stopped to get ready for a board, we went to pull the first rider up, got to about 15mph and the boat died. Throttle obviously somehow set to closed, release throttle and reapply, nothing! Engine still idling, shifting into F and R no problems, but lost throttle altogether.
    Switch power off, restart boat, throttle comes back online and away we go.
    This happened 3-4 times, and then was fine for the rest of the day.
    Could there be a loose connection somewhere? Is the sensor in the throttle prone to failure? Is the servo in the TB a known troublemaker? Is there any way for me to test which was causing me grief if it ever happens again?
    On a side note, my zero off has been playing up every now and again (NO GPS or GPS signal lost) although they would share a few signals like throttle position to activate, I find it hard to believe they're related but thought I would give this info just in case.
    cheers
    Arron
    2008 210
  • Miljack
    • Dec 2004
    • 1615
    • Charlotte, NC
    • '08 230 TE ZR6
    Arron,
    I have an '08 230 ZR390, and we have experienced the ZO funkiness a couple of times, same symptoms as you described, but, I just "rebooted" the boat, and the problem disappeared.
    I've heard the ZR engines had a throttle position sensor that can go bad, maybe the same thing on the Excal engines?
    The problems could be related as the ZO is function off of the ECM and the TPS is part of the system...
    2008 230 TE-ZR6
