Ignition Failure Code
  • jimcomeaux
    • Jun 2013
    • 1
    • austin
    • none yet
    getting an ignition failure code when trying to start my 2004 216te
    boat cranked for a minute, wouldnt start then starter would engage
    any clues?
    jim
  • s_kelley2000
    • 1575
    • Fort Meadow Recevoir
    • Mass
    Are you getting this code on the dash or with a scan tool? Which engine? The starter not engaging could be the solenoid or relay going bad. I doubt saftey lanyard if it is throwing a code but always good to check that. check your grounds as well.
    Shawn
    2012 Blue Metal Flake SAN 230
    • dfoster
      • Mar 2012
      • 134
      • Northborough, MA
      • 2004 SV211 TE
      Jim,
      Which engine are you running? Based on the year, I am guessing it is a MEFI-4 based engine. I have a copy of the PCM MEFI diagnostics manual which may help, just PM me your e-mail address.
      The MEFI requires a Cam and Crank sensor. It will check that signal and if it isn't getting one it will throw an error and not let the engine start. My guess is that it is something like that.
      There are a number of different DTC codes that can be read with a scanner. Those codes will tell you the difference between a coil failure or a crank sensor. My guess is that the gateway box just lumps those all into "Ignition Failure", but there is no DTC code for that.
      The scanners are like $50 for a basic flasher, or $600 for a pro-tool at rinda (http://www.rinda.com/acro/prodlist.pdf)
      Or if you are geeky like me, you can make your own. http://www.offshoreonly.com/forums/d...%241-00-a.html
      I used that information to clear an error with a paperclip!
      Good luck with the testing, hopefully it is something simple. Let us know more details, and we can try to be more helpful.
