Correct hull prep for new graphic???
  • 1955 classic
    • Apr 2013
    • 39
    • New Zealand
    Can anyone suggest the correct way to prep the side of a hull for a new graphic, obviously a good clean and removing the old graphic is the easy part. Then cleaners or buffers??? ( doesn't seem to be faded gel coat).
    Removing standard 220 graphic and have new Griffen graphic and lettering from a PN member
    Main worry is removing all contaminants so new graphic will adhere properly.
  • shag
    • 2217
    I have always had goo luck with using rubbing alcohol on a clean cloth - rub the entire area well. Then use a vinyl squeegee to help get out any small air bubbles after application.
