Sherwood Pump Pulley
  • toddrswenson
    • Aug 2004
    • 222
    • Pearland, TX
    • 97 Ski Nautique GT-40 LOVE IT
    The pulley on my Sherwood pump on my 2002 GT-40 is bent. I'm not sure how it happened. It may have been that way when I bought the boat last year. I'm wondering if it was done when changing a belt someone may have put a pry bar in the groove for tension and bent it. Everything runs fine, but the belt has premature wear. Can the pulley be replaced or do I need to buy a new pump?
    2002 Air Nautique GT-40
    97 Ski Nautique GT-40--- Sold
    LOVED IT
  • crobi2
    • Dec 2010
    • 337
    • Texas
    • 2000 Super Air Nautique
    I replaced my pump last year after the bearings fell out and it started sucking air.
    I did not look super closely at the fit of the pulley to shaft, but it seemed like a fit so
    tight you might destroy the pulley taking it off.
    If yours is wobbling really bad, your bearings and seals may not have much life left anyway.
    P.S. If you do keep using it, when it starts sucking air, the engine should go into "limp mode" when the temp gets to 200F.
    Rob
    2000 SAN
    • jbach
      • Aug 2012
      • 187
      • the state, not the jelly
      • 1999 SAN
      mine had the same problem, when running the pulley appeared to be bent. in actuality, the earings/bushings were shot and the only thing keeping it relatively straight was the impeller. mine never went into limp mode, just ran hot due to sucking air.
