2006 PCM 330 remote oil filter leaking
  • 1955 classic
    • Apr 2013
    • 39
    • New Zealand
    I have a leak from the oil filter lines(one much worse than the other) that run into the remote filter housing.(it is definitely not the filter leaking).
    I have replaced the Orings and even changed Oring sizes as a last resort, but cannot stop this leak. I cannot visually see any cracks in pipe or remote filter casting. It appears the oil is bypassing the oring and coming through between the stainless pipe and the large brass nut
    I have found an old thread saying there was possibly issues with these, but not much information overall. Has anyone got/had a similar problem and found a solution, or do i just start by ordering a new filter housing, and then both oil hoses if it doesn't stop.
    Thanks in advance for any help
