05 SANTE Faria Gateway and PerfectPass question
  • Spencermo
    • Jun 2013
    • 77
    • Ohio
    I have a new to me 05 and I am trying to still understand everything with the boat. Can some tell me what actually the Faria Gateway box does?
    Also anyone know what model of PerfectPass is in these boats from the factory? Location of the PP module?
    Thanks in advance!
  • grkero
    • Dec 2010
    • 65
    • Northern California
    • 2005 SAN
    Thanks in advance!
    The only thing I can help with is the PP module is installed underneath the dash. So if you take out the 4 screws and lift that pod up, it should be under there.
    2005 Super Air 210 (white/black) - EX330
    1991 Barefoot Nautique (red/black) - 454 chevy w/ v-drive
    • scottb7
      • Aug 2011
      • 2198
      • Carson City, Nevada
      http://faria-instruments.com/site_manuals/IS0219_A.pdf
      • Quinner
        • 2246
        • Correct Crafts
        If factory pp it's most likely the wakeboard pro edition, it can be toggled to the pro edition if desired, perfect pass should have a manual on their site if you need one.
        The gateway controls all your gauges and your pp is also tied to it I believe, your pitot tubes go to it as well which is converted to a digital signal sent to your gauges. If you are in a climate that freezes it's not a bad idea to remove the pitot lines when winterizing as some did not always self drain and could back up ice/water into the gateway
        • NCH2oSki
          • 1159
          • Maryville, TN
          • 2005 ski nautique 206 SE
          What series or edition is your 05? Did they have the SE available for the sante's also or just the ski boats? I have an SE and dont have pitot tubes or a gateway. I have a paddle wheel that connects to a rheostat type knob then on to the speedo.
          Prior Boats:
          1999 Ski Nautique GT-40
          www.skiersofknoxville.org
          • Spencermo
            • Jun 2013
            • 77
            • Ohio
            Thanks for all the help so far. NCH it is a Super Air Team Edition. It has the pitot tubes.
            Does anyone know if it is easy to change out to a system such as NCH is referring to??
