Intake for 5.8 with gt- 40 heads
  • shammy
    • Feb 2014
    • 1
    • riverview fl
    • Shamrock with 5.8 - gt -40 heads
    Bought a Volvo efi 5.8 . I am going to convert back to a carburator,as the efi is no good,need to know if I can use a stock 351 intake or is there an after market option. Thanks for the help
  • east tx skier
    • 1561
    • Tyler, TX
    On my old MC Ford 351 HO (GT40 heads), I had an Edelbrock performer intake, and it was a very nice mid range torque bump. It added height, however (about 1"). So check your clearance and compatibility with the Volvo.
    • TX-Foilhead
      • Mar 2009
      • 351
      • Kingsland TX
      Not sure which version of that motor you had, I've seen 2 versions of OMC's one with 250hp and another with 300hp. The 250 has 19lb injectors which are orange, the 300 should have 24lb injectors which should be blue. I would also expect the 300 to have GT40 heads and a different cam. Just like the carb'd boats, GT40's or GT40p's would be a nice upgrade with a Performer/Performer RPM or Stealth intake depending on what will fit in the budget and under the hood.
