Zr 450 Pcm v-drive transmission lubricant questions?
  • fatchance720
    • May 2013
    • 75
    • Olympia, WA
    • 2013 G23 450 2011 Axis A20
    I want to change my transmission fluid but I can not seem to find any mobiltrans shc 50 synthetic transmission lubricant (r190250)? I have a zr450 v drive. Can anyone help?
    Also do people typically prefer the sae 15w-40 synthetic for oil?
  • shawndoggy
    • Aug 2011
    • 151
    • Reno
    • MB Sports TWB 23
    http://www.nautiqueparts.com/pcmv-driveoilquart.aspx
    • vision
      • 517
      • NC
      • 2013 G23
      Why changing? PCM states not to chamge unless there is an issue.
      • durty_curt
        • Feb 2010
        • 52
        I second the v drive statement above. You don't need to change it unless you're having problems. Down here in AZ we use 10W40 full synthetic. I have a few friends that run 5W40 full synthetic in their PCM.
        • fatchance720
          • May 2013
          • 75
          • Olympia, WA
          I was just told it was supposed to be done. That's why I have you guys here! I wonder about the heat difference with recommending oils. I am in WA and temperatures can fluctuate a lot. Typically over 50 though.
          • nms1991
            • 477
            Are you taking about changing trans fluid or the v-drive fluid? The transmission uses regular transmission fluid dextron III or IV but the v-drive uses the 50 wt synthetic. they are two separate units like a four wheel drive truck transmission is separate unit from the transfer case.
