Bilge pumps run every 20 seconds
  • kend
    • Oct 2013
    • 193
    • DFW, Texas
    • current 2001 Air Nautique previous 1988 Sanger DX
    Turned everything off lastnight and it had maybe 6gal pump out this morning. I could just hear the back running I think it had been a long time since it had run since I usually trailer
    Ken
    2001 DD Air GT40
    • vision
      • 518
      • NC
      • 2013 G23
      If you pumps are running every 30secs and you have that much water in you hull, then I suspect you have a leak. While my pump runs about every minute as part of its normal programming, I rarely have any water to pump out.
      • Ewallace
        • Mar 2012
        • 83
        • Park Hill, OK
        • Air Nautique 211-SV TE
        If you have a heater in your 211, your heater core could have frozen and cracked.
        • yager97
          • Apr 2010
          • 33
          • Ontario, Canada
          • 2004 Nautique SV-211 Team Edition
          Just to update on this, I replaced both pumps and two new batteries. Everything is working fine now, the duration and frequency of the bilge pumping running "checks" has been reduced to normal timing, and the checks duration is not as long as it previously was.
