Turned everything off lastnight and it had maybe 6gal pump out this morning. I could just hear the back running I think it had been a long time since it had run since I usually trailer
If you pumps are running every 30secs and you have that much water in you hull, then I suspect you have a leak. While my pump runs about every minute as part of its normal programming, I rarely have any water to pump out.
Just to update on this, I replaced both pumps and two new batteries. Everything is working fine now, the duration and frequency of the bilge pumping running "checks" has been reduced to normal timing, and the checks duration is not as long as it previously was.
