Jabsco Ballast Puppy alternative
  • Luke 'Lukey' Thomas
    • May 2012
    • 22
    • New Zealand
    Does anybody have any good recommendation for an alternative to a Jabsco Ballast Puppy? I need 3 replacements, and don't fancy spending the $400 odd New Zealand $'s for a replacement Jabsco if theres a decent alternative around?
    Anyone had any luck with similar reversible pumps?
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    The Johnson F4B11 is a comparable 12V reversible impeller pump, but its not much cheaper then the Jabsco here in the US.
    • s_kelley2000
      • 1575
      • Fort Meadow Recevoir
      • Mass
      Are you sure the pumps are dead? I have rarely heard of these pumps failing and it seems odd that all 3 would fail on you. If you haven't already I would check impellers, wiring, fuses/breakers and switches before buying new pumps.
      Shawn
      2012 Blue Metal Flake SAN 230
        • May 2012
        • 22
        • New Zealand
        2 of them are OK, 1 of them has corroded to ****! Unfortunately the pumps were removed by the previous owner and left exposed to the elements one winter! Been on the replacement list for a while, but one finally gave up the ghost. I replaced the impellers last year. Thanks for the help.
        • scottb7
          • Aug 2011
          • 2198
          • Carson City, Nevada
          Can you rebuild them?
