Blower not kicking on
  • Jalmeter
    • Aug 2013
    • 58
    • Edwardsville IL
    • 2008 Super Air Nautique 210 Team
    Just as the topic says, my blower is not kicking on. When I push the button on my key pad, it clicks, but no light turn on. Thoughts?
    wakeboardSTL will return
  • ddipert
    • Nov 2013
    • 116
    • Mebane NC
    • 2010 SANTE 230
    Should be simple wiring to check.
    Do you get power at the fan? Use a test light or volt meter and check.
    Sounds like your getting power to the relay (which is the click) if that is the case your button and relay are good. Might be a loose connection at the fan or a bad fan.
