When I push in the accessory buttons to turn on something like bilge pump, lights etc they go in and stay in. There is no way to turn the accessory off. The blower wouldnt stop last time I used the boat so I had to undo the pos cable from the battery. Any one know what is wrong with the panel buttons?
- Nov 2007
- 1575
- Fort Meadow Recevoir
- Mass
- 2012 Super Air Nautique 230 1999 Nautique Super Sport with 502 Python (for Sale)
Welcome to the site. Are you new to the boat or is this a new problem that just started happening? If you are new to the boat then it is probably user error. You push these breakers in to turn make them active and then if you push them in again they will spring back to the original position and turn the accessory off. Sometimes they get bad and are really hard to push in and they don't want to spring back. If that is the case you can get the replacement breakers at Nautiqueparts.com (use code PND to save 10%).Shawn
2012 Blue Metal Flake SAN 230
A d m i n i s t r a t o r
- Mar 2002
- 16462
- Lake Norman
- Mooresville, NC
- 2025 SAN G23 PNE 1998 Ski Nautique 1985 Sea Nautique 1980 Twin-Engine Fish Nautique
These are a very common wear item. You can replace them here:
http://www.nautiqueparts.com/circuitbreakerswitch.aspx
Be sure to use the PN discount code (PND) when ordering.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I had good luck pulling my dash and spraying the front and the back of the relay / breakers with silicon lubricant. Work much better now. (likely less greasy than WD40 as well).2004 206 Air Nautique Limited - Black with Vapor Blue (family style)
Bellevue WA
- Sep 2010
- 283
- Gainesville, FL
- '02 Ski Nautique '87 Barefoot Nautique - sold '97 Super Sport - sold '96 SN196-sold '83 2001 sold
Don't take this the wrong way but it seems like possible user error. One, two, maybe a few stuck I could see but to have all 10 of them stuck I'm thinking you aren't pushing in far enough and swift enough to get them to click and return back. Try using a clicker ball-point pen without the end sticking out. Use the end of the pen to push in all the way. Sometimes you have to give it a little authority.2002 Ski Nautique 5.7 GM Apex
