Impeller replacement
  • 95skinautique
    • Jun 2011
    • 17
    • Johnson City Tn
    • 1995 Ski Nautique Open Bow
    I have a 351 ford engine and i need help locating the impeller housing. I believe it is in the bottom right pulley, but i can be mistaken. And also best way to remove the impeller.
ID:	381331 Click image for larger version
Name:	photo 2 (2).jpg
  • Nautiquehunter
    • Jun 2008
    • 2080
    Thats it . Two 1/2'' mounting bolts remove the complete unit . MARK the two halves of the housing then remove the three 7/16 bolts holding the two haves together. NOTE the pump assb can be installed upside down if that occurs it will not pump water . Either mark it before you remove it or remember the two hoses are on the engine side
    • bhectus
      • Sep 2010
      • 283
      • Gainesville, FL
      • '02 Ski Nautique '87 Barefoot Nautique - sold '97 Super Sport - sold '96 SN196-sold '83 2001 sold
      That should be a simple 15 minute job. May take you a little longer on your first go-around. Man do I miss how easy it is to do an impeller replacement on a GT40. My Apex is a royal PITA!!
      2002 Ski Nautique 5.7 GM Apex
      • 95skinautique
        • Jun 2011
        • 17
        • Johnson City Tn
        Thanks and how do I tell which impeller I have or is there just a standard??
        • bhectus
          • Sep 2010
          • 283
          • Gainesville, FL
          here's the one you need:
          http://www.nautiqueparts.com/sherwoodimpellerkit.aspx
          • 95skinautique
            • Jun 2011
            • 17
            • Johnson City Tn
            Hey guys I just thought that I would keep my business local and them order the impeller for my sheerwood pump. It came in today so I had my brother go and pick it up and he told me that is an emp replacement for the sheerwood. Has any one heard of them?? Are they worth getting??
