2002 Super Sport Need Help with Ballast Install
  • macpres
    • Feb 2014
    • 94
    • ST Paul
    • Past: 2002 Nautique Super Air 2018 G23 2019 G23 2006 Wakesetter 247 2020 G23 2021 G23 2022 G23 2023 G23 2024 S23 2024 G23 2025 G23 2024 GS24 2005 Supra Launch 21V Current: 2025 G23, 2023 Malibu Response and 2005 SANTE
    Guys, looking for a little help here, hoping someone has some experience or pics on installing ballast on my 2002 Super Sport. I purchased a loaded up setup from wake makers and asked if they could send a diagram but its been a few weeks and starting to get warm and i can't wait any longer! Installing a brand new New Dimension Tower with Racks and Bimini this weekend! also ordered an alarm from Flagship Marine Security i will be installing and posting pics of the process for you guys to check out! I appreciate the help!
    Boat Details:
    2002 Nautique Super Sport V Drive
    One Owner 120 hours
    red and white
    i've never seen a cleaner boat!
    Below is the parts list:
    Johnson Ultra Ballast Reversible Pump 23001 3
    Reversible Ballast Pump Install Kit - Johnson Ultra Ballast 34021-23001 3
    1" Bronze Mushroom Thru-Hull Intake 35001-100 3
    1" Bronze Ball Valve 35003-100 3
    1" Thread x 1" Hose Barb Fitting 32014 3
    1" Ballast Hose Black 31001-100 40
    Flow Rite 1" / 1-1/8" Barbed Elbow Quick Release Connector W746 33046 4
    Fly High 1" Flow Rite Quick Release Connect W743 33043 4
    Fly High Pro X Series Fat Sac - Gray 11007-gry 2
    Fly High Pro X Series Integrated Bow Sac - Grey 11011-gry 1
    Fly High 3/4" Flow Rite Quick Release Connect W736 33036 4
    Flow Rite 3/4" Elbow Quick Release Connector W742 33042 4
    3/4" 90 Degree Thru Hull Fitting - Composite/Stainless 36001-340 3
    3/4" Stainless Steel Hose Clamp 31003-340 6
    1" & 1-1/8" Stainless Steel Hose Clamp 31003-100_118 16
    3M 4000 Marine Adhesive 37003 1
    3/4" Ballast Hose Black 31001-340 20
    Fly High Pro X Series Tube Sac - Grey 11004-gry 1
    Ballast Switch Cover Upgrade Package 90256 1
    Ballast Rocker Switch Cover - Right 37014 1
    Ballast Rocker Switch Cover - Left 37015 1
    Ballast Rocker Switch Cover - Front 37016 1
    Ballast Rocker Switch Body 34013 3
    3/4" Hose Barb Tee Fitting 32022-340 1
    1" Hose Barb Tee Fitting 32022-100 1
    3/4" Inline Check Valve Fitting 32003-340 1
  • Brichter14
    • Jun 2013
    • 531
    • Central Illinois
    Only concern is that you have three pumps dedicated to one 1" thru hull. I used aerator pumps not reversible but here is my install.
    http://www.planetnautique.com/vb3/sh...f-Photos/page4
    • macpres
      • Feb 2014
      • 94
      • ST Paul
      I have 3 thru hulls as well as 3 pumps
